There was an DVD burning article in the local paper (SJ Mercury News) that contained the following:
Is this true? I thought the whole purpose of -RW disks was to allow you to re-record. How could finalizing it render it into a DVD-R disk? I have a feeling they're wrong.The DVD-RW disk has formatting issues that allows you either to record, edit and re-record or to record and play -- but not both. Once you finalize the recording session on a DVD-RW disk, it will play in almost any player -- but there's no going back to erase and re-record. If you leave your editing session open for more recording, the disc will play in a very small number of players.
You can always erase a DVD-RW whether it is finalized or not (Roxio's software and TMPGEnc DVD Author can both do it), but you do end up with a empty disk. I don't believe that you can selectively choose which video to keep and which you want to erase. I guess that the SJ Mercury News article is implying that you cannot add video to a finalized disk, which is true, but you can always erase and start over.
Ned -
Indeed -- the same is true with Nero and probably most burning software -- RW disks can be erased and re-recorded -- that's why they are RW.
Finalized -RW need to erase to record more. Finalized +RW can add more after finalization without erase. The + spec is, well, better.
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
What's you basic means of transportation?
By johns0 in forum PollsReplies: 19Last Post: 19th Sep 2011, 06:59 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
What does cable-in-the-clear means ?
By SingSing in forum Video Streaming DownloadingReplies: 1Last Post: 31st Mar 2010, 20:14 -
What happens to the disk when finalizing?
By hurricane1951 in forum Authoring (DVD)Replies: 3Last Post: 19th Sep 2008, 22:54 -
how to record from the HDD to a DVD+RW disk, using a Yamada DVR-9300HX
By The Muddler in forum DVD & Blu-ray PlayersReplies: 7Last Post: 1st Aug 2007, 13:00
