I have tried using tmpgenc to convert divx to svcd and when i do, the result is strected vertically but when I try the same with vcd its fine.
I have been using full screen (keep aspect ratio) on both attemps but on vcd seems ok.
Please help.
You do realize that all AVI's have a 1:1 aspect ratio? Resolution has nothing to do with Aspect Ratio.
Resolution does affect how it's resized. It's the resizing causing the problems. Most downloaded AVI's are made from 16:9 and Anamorphic sources, hence the 640x360 resolution (yeah I know, it's confusing). Resizing 640x360 to 480x480 is going to give you a 480x270 with a LOT of black border if done right. If not done right you get 480x480 with no borders and REALLY stretched in the vertical.
Make any sense?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I understand but still cant get the picture right, could you try to explain hot I do it please.
I have a 640 x360 as you said but im not sure what settings to get it to work correctly as wide screen as svcd, please help.
Thanks in advance. -
Use svcd2dvd and when you load up an avi change the aspect ration from 4:3(no borders,encoded as 4:3) to 16:9(border added,encoded as 4:3).When the avi are full screen dont change the aspect ratio.If you do use this method remember to change the rate control mode in the encoder tab to the preferred method.
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 20:36 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
I have a problem with TMPGEnc 3.0 with DivX...
By blasedeviant in forum Video ConversionReplies: 2Last Post: 1st Feb 2008, 22:10 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
