1, I plan to buy a LG GSA-4040B. But I doubt that my pc will support it. My pc config is quite old, CPU Celeron 600Mhz, 448MB SDRAM with win2000 server installed. Can I use LG GSA-4040B to burn my DVD if I only burn it at 2x speed?
2, From the review, the quality of the blank DVD-R disk varies a lot. But It seems pinco and TDK cause less burning errors than others. What DVD-R disk do you guys recommend?
Thnx.
From spec introduction. LG GSA-4040B requires windows OS, but does not mention CPU frequency. So can I buy it? Someone said the mini cpu requirement is 700Mhz. Is it true?
newbie questions about ffmpegx
By Anoni in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 11:11 -
couple newbie questions - DVD to MKV and watch on WDTV
By timmyinnis in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2010, 04:14 -
Newbie Software Questions
By AAOBill in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 00:42 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 15:16 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 14:51
