I just got this capturing thing hooked up to my computer. I have a Radeon Ultra 64mb. I hooked it up to my vcr and it plays on my monitor. When I try to capture, it only saves the captured file in mp2 format. Is there a plugin or another freeware program that will let me change my mp2 to another format that tmpgenc uses? please respond thanks.
Are you using MMC? MMC only let you capture video in Mpeg format. I use Virtualdub can capture video in AVI format, it's a freeware with lots of feature. but you must setup a WDM capture device for your ATI capture card.
<font size=-1>[ This Message was edited by: VideoMax on 2001-10-13 00:26:27 ]</font> -
Videomax,
I'm assuming from your post that you have an ATI card of some sort. What codec do you use when you capture through Virtualdub?
Cifcap -
The mp2 file is a mpeg 2 file just rename it and it will be fine in tmpg. And MMC does allow avi capture.
Capturing VHS with ATI TV Wonder HD600 PCI card
By CamaroDMD in forum Capturing and VCRReplies: 12Last Post: 17th Jun 2010, 08:58 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 01:10 -
going CRAZY: capturing with ATI HD 3600 (analog)
By nuzumaki in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2009, 18:24 -
ATI ALL in WONDER 9600 TV & capturing problem
By ikeogut in forum Capturing and VCRReplies: 35Last Post: 31st Aug 2008, 05:51 -
Capturing from Hi8 Tapes using ATI or Dazzle DVC 90 ~more info inside~
By samyrk in forum Capturing and VCRReplies: 12Last Post: 18th Jul 2007, 09:54
