Is there an easy way to determine the correct field order for an interlaced DVD source?
Yes . It is Top field first.
If you get VirtualDubMod , on the file open menu there
is a "popup extended option" checkbox that lets you separate or reverse
fields. You can watch that and see if its right
Edit: Never mind. I just tried it and it apparently only works for AVIs.
TMPGenc shows fields in Advanced - IVTC -
Read here: http://www.inmatrix.com/articles/ivtc1.shtml
Under: Selecting the correct field order
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 07:04 -
Field Order When Converting HD source to DVD
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2008, 01:22 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
