I have a VCD that I bought and I wanted to know first how to convert it to MPG. Then since it is two big for one CD (750mb) I need to know how to cut it so I can burn it. I believe I can use tmpgenc,but I don't know know? Can someone help me?
you said you bought a vcd. then you shouldn't have to convert it if its a vcd. But there are many guides here for converting.
You just have to change the .dat file to an .mpg file. I think vcdgear does that. Maybe you can just rename it, I´m not sure.
If you want to burn it to a cd you have to burn it as a vcd to fit it on the disc(when you burn a cd-r like a vcd it actually fits more, a 700 mb cd fits about 800 mb when burned as a vcd) check the tools section on the left for the software you need.
By Krissu in forum Video ConversionReplies: 3Last Post: 7th Nov 2011, 14:05 -
converting from 30i to 30p with Virtualdub; before or after cutting?
By CFPJer in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 22:17 -
Converting, cutting, and joining audio files in an only software!?
By coxanhvn in forum AudioReplies: 4Last Post: 22nd Feb 2008, 23:44 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
