Whats a good prog to convert mjpeg movies taken with a digi camera to mpeg so i can make them smaller and send over the net .
thanks in advance.
MPEG is smaller, but not small. DivX/WMV9 is probably the smallest you can make it and keep excellant quality. Both use MPEG4 encoding which is roughly 1/3 the size of MEPG2 encoding for same quality.
MPEG4 is better for very small files (hence reduction in quality). You are looking at 5 MB/minute roughly for VHS quality.....but it all depends on the source video.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I should have pointed out that it is not a movie camera but an olympus 750 digital camera which has a movie mode option with sound .
The movie clips are ok but not many folks i know have the pci jpeg codecs on there pc hence the reason for wanting to convert.
Convert to MJpeg
By gmellow in forum Video ConversionReplies: 18Last Post: 29th Jan 2015, 05:21 -
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
MJPEG export
By vizion in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2011, 12:52 -
Divx/Mjpeg to Mpeg-4 with VirtualDub
By nalooti in forum Video ConversionReplies: 2Last Post: 16th Nov 2007, 22:50 -
MJPEG Testing
By adambklyn in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 01:04
