Can someone help me out here? I’m wanting to find out, when a dvd has been backed up onto the hard drive using DVD Shrink, it has VOB files and bup and iso files. The DVD I backed up, is too large to fit to dvd even after being shrunk by DVD Shrink 3.0 Beta version according to Nero Version 6.0.0.19.
So I’m trying to open up the VOB files and other files associated with the dvd which are ones that aren’t particularly needed like previews of other movies etc. I need to find out, with the VOB files and associated ones, if I delete Vts_20_1.vob, does that mean that the other Vts_20_0.vob file that won’t open anyway, is also associated with the one I deleted so therefore can also be deleted? Also does that mean I could get rid of the other files that start with Vts_20_1 or Vts_20_0 with bup or ifo as the file extension?
Or if you have any other way that I am able to shrink the video just about 100MB or so more without deleting any files, please let me know.
Thanks in advance for any help.
If you delete VOBs outright and ever try to access whatever part of the DVD they belong to you'll get a big problem. You should have just dumped the original and ran it through DVD Shrink again making sure its small enough the 2nd time.
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 00:31 -
authoring dvd using a group of vob files
By sumeshkri in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2008, 10:23 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 17:52 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 01:05 -
What authoring programs offer fit to disk using .avi files?
By dang in forum Authoring (DVD)Replies: 2Last Post: 16th May 2007, 21:05
