Hey all-
Need help from these forums as I still can not create an SVCD without major hassles.
I have Win2K (SP2) and ATI AIW card. I have TMPGenc, VirtualDub and of course MMC 7.1. I also have the Huffy codec installed. I recently installed the wrapper for W2K (thanks to the forums) and can now capture in eithe MMC 7.1 or VirtualDub. Here's where it gets weird...
When I try to capture in VirtualDub I can not change the "YUxx" settings (can't remember the default). Furthermore I can not change the size to 480x480 even when using the custom setting part of the program. So I live with it and capture a .avi at the default settings but lose TONS of frames.
Here's where it gets weirder...
Whenever I launch TMPGenc or VirtualDub a DOS window opens up along with the program with weird lines of code appearing as I change settings and use the program. If I close the DOS window it closes the window plus the app that generated it. It's quite unsettling and I wonder what's causing it.
So here's my workaround to capture and burn to SVCD (hardly a workaround)...
I capture using ATI TV program directly to .avi using the Huffy codec. I then encode the file to an SVCD compliant MPEG2 then burn with Nero. Problem is... for even two minutes of a/v it takes 15 minutes. For 5 or 10 minutes I'm looking at an hours wait.
I have scoured the forums and have lots of software and have played with all my settings... how can I more efficiently capture for SVCD and more importantly what's with those damn DOS windows!!!???
Thanks all - I would not be able to stay with this and make progress without the forums!
mk
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 06:59 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 15:08 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25 -
the weirdest harddrive/ripping problem ive ever seen
By ted demen in forum Newbie / General discussionsReplies: 12Last Post: 10th Feb 2008, 21:20
