I have a question about "TMPGEnc". T VCD's that I've made so far using "TMPGEnc" have played pretty well. The question I have is, why is it that my VCD, will play in some DVD Players, and not others? on the "Stream Type" I have been using "Video-Cd (Non Standard). Should I use "Mpeg-1 System (Automatic)? I would like it, so that the VCD's I am making, will play in anny DVD Player I put it in. Can someone please tell me, what I may be doing wrong? Any help, would be appreciated...
Yes, this, or Video-Cd is the only muxing types that work. Mpeg System doesn't work. Not all DVD players play VCD, so you can't achieve your goal. Your best bet is to use the VCD wizard in TMPGEnc, then author with VCDEasy. That way, you'll create VCD that will play on most players.I have been using "Video-Cd (Non Standard).
/Mats
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 20:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2008, 00:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 09:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 05:38 -
FitCD / TMPGEnc question
By Seroster in forum Video ConversionReplies: 4Last Post: 3rd Sep 2007, 13:34
