Had very good luck with 3 beta 5 , ran program 4 times w/o a hitch. Ran today, while disc was analyzing, BANG...system crash. Tried 2 diff films,both same results. Removed and tried ver 2.3 and had same results. System memory is fine (640MB) Have power supply monitor...shows no problem. Did windows error reporting,came back "Device Driver Error" . HDD? DVD-Rom? Vid card? Just updated Vid card drivers(SB Live). Any clues?
Yea,that's what I like!
I've read other post of same problem, power supply issue possibly? Have 430 True Power AND MBoard monitor. Certainly not that. Also tried Shrink 2.3 and had same results. Time marches on......
Yea,that's what I like! -
If you just updated drivers and the problem started, that's the clue. If you didn't make any changes, that's a little harder. I doubt it's a PS problem. Most likely a bad driver. You have XP, do a restore to an earlier setup. Before that, you can also go to Control Panel>System>Advanced>Startup and recovery and set not to restart after problem. May not help, but it will give you some more info.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
System Crash
By maximusbob in forum SVCD2DVD & VOB2MPGReplies: 22Last Post: 10th Dec 2007, 20:09 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
Pioneer DVR112d maybe faulty won't read dvdrs and makes system crash!!
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th Jun 2007, 03:44
