i am trying to put several mpeg-1 files on a dvd. when i create the dvd folder with the vob files most of the videos are fine except two of them are out of sync. ive read some posts about this and it looks like this is usually caused by bad frames. i checked the video files in virtualdub and it says there are 0 bad frames. ive tried encoding to mpeg 2 files with tmpegenc. i have even tried demultiplexing and remultiplexing the audio and video streams just to see what would happen and even that got the audio out of sync. all these files are from the same source and work fine before i do any converting or encoding. so how can i find out what the problem is? how can i find out what the difference in these two videos are? thanks for any help you can give.
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Audio out of sync after DVD authoring
By dexter30 in forum Authoring (DVD)Replies: 7Last Post: 29th Oct 2010, 18:27 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21
