Recently purchased an Avermedia DVD ezmaker USB2.0 which came with neoDVD. I captured some video footage off my camera using DVD quality settings...I then went through the process of creating a DVD-Video with a titles etc. I then burned the 8 min DVD-Video to a CD-R using the "copy" function in neo DVD. It showed that it was successful.
Here is the question...I can watch the DVD (on CD) off my PC but when I try it in my Apex or Samsung player it does not work. In the Samsung it hangs on loading and on the Apex I get "Invalid Entry"...
Any ideas as I have had no probs before with these players playing any burnt videos (mostly vcd's, svcd's)?
First make sure you have selected the disc format of DVD-Video (in the "create page lower right corner), then select the quality level you want (best, better, or good).
When you select "make a disc" you must then select from the pull down menu the following.
Disc Format + DVD-Video
Viewable In = US (NTSC) assuming you're in the states.
I always write to my hard drive from Neo then use RecordNow Max to do the actual burn. All the files Neo generates must be in a VIDEO_TS folder then you burn that folder. Also the disc must be finalized or closed after the burn. I believe if you write directly to disc NeoDVD will put all the files into a VIDEO_TS folder for you.
NeoDVD is a simple program that works very well and fast for what it does. Good luck.
Hi,
The DVD video you created on a cdr is called miniDVD, which most of the DVD players will not play. Please see the "Glossary" section under "miniDVD" for further information.
cchang -
Thanks cchang...I was unaware...always thought miniDVD was on like a mini disc (ie. Sony...)...you are correct...checked the list and my DVD players do not recognize that format....
I did not choose VCD, cause i was looking for the best quality...neo does not offer SVCD...only DVD or VCD....Originally Posted by MysticE
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
