well i'm new to makin dvds so here's my progress : i made a video file with tmpgenc and exracted the audio to mp3 then to ac3
now what should i do with the author i got tmpgenc author but it don't accept the ac3 audio file and says it only takes mp layer 2 files though i heard here that ac3 is the best and most commonly used audio format so will another auhor program accept the ac3?
thnx![]()
tmpg dvd author will take a m2v file and a ac3 ,thats all i use, you cant hear the ac3 file in tmpg dvd author cause it dont support ac3 , but when the disc is burnt you will hve sound
TMPGEnc DVD Author does accept AC-3 files so my guess is that you did not create your AC-3 file correctly (and it is being rejected for that reason) or ... that's all I can think of.Originally Posted by brock_leznar
might be the original audio--(your mp3)--rip the same file and save it as a wave file instead of a mp3 then convert to ac3.
.m2v + .ac3 + .sub/.sub to .mpg
By stevie99 in forum Video ConversionReplies: 2Last Post: 9th Apr 2012, 04:01 -
HD .m2v and .AC3 Help Needed Please
By lovelylisa in forum Video ConversionReplies: 40Last Post: 29th Jun 2011, 09:20 -
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 03:21 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 18:24 -
how to convert .m2v + .ac3 to .flv
By r00kie in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 20:24
