I just finished about 20 short films, averaging about 6 or 7 minutes each. A 7 minute AVI file takes up about 18 GB of storage. I need to get these files off my hard disk, but I don't like the idea of chopping up these big files into smaller files to in order to spread each file across 4 or 5 DVDs.
Is there a way of compressing these 18 GB files into another format that would still allow me to go back and edit them and not lose too much quality?
Thanks.
Results 1 to 9 of 9
I was in the same situation and started copnverting these to *.wmv files using Windows Movie Maker 2 or Adobe Premier Pro. You can up the bitrate from the level that I used and get pretty good quality. My intent was for making video that could stream over a standard DSL line so I chose a bitrate of approxmitaely 340kbs and i was getting a 100:1 file size compression. Yopu could choose a 10:1 compression and get pretty good quality thats not as good as DV but acceptable.
Goodluck,
VCThis is so much fun! -
Load it in Virtualdub, video>full processing mode, video>compression>pick a codec (foo suggested one)>configure, audio>direct stream copy or full processing then pick an audio compression too. Save avi.
"Art is making something out of nothing and selling it." - Frank Zappa -
I tried to do ur steps zippyP... But then the video will be jumpy..
Basically, all i used was the DivX codec.. -
"Load it in Virtualdub, video>full processing mode, video>compression>pick a codec (foo suggested one)>configure, audio>direct stream copy or full processing then pick an audio compression too. Save avi"
Zippy, once I pick a codec (Picvideo) how do I configure it? I can't seem to find a good walkthru for this. I want to compress this so that I can video stream it. Thanks. -
I've never used picvideo, maybe Foo can help.Originally Posted by pdragonfly
Here's a vdub video compression guide."Art is making something out of nothing and selling it." - Frank Zappa -
You just download and install the PicVideo codec.
Then when you go to save a video in Vdub it will show up in the
compression list and when you pick that , you get an option to configure.
The onlly choice IMO is compression level 18,19,or 20.
I use 19.
They want money for it (not much) but the demo works and just has
a watermark. -
Thanks I'll try that. I don't mind buying it if it works.
Now if I can only get it to play on a MAC I'd be a happy dragonfly.
Trying to convert AVI to MPEG file smaller then 4gig
By Lisn2me in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2009, 12:01 -
Convert Digital Camera avi's to smaller size
By nook in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2008, 07:13 -
Simple Qu.- DVD disk -> Convert/Encoded (smaller) -> play on old stan
By chi1234 in forum Video ConversionReplies: 1Last Post: 13th Jan 2008, 05:03 -
How do I make a AVI Smaller?
By gottiman in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2007, 05:35 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 12:29
