Hello, As the title says I am having some play back problems on my stand alone DVD player. They are MPEG-2 files that I downloaded of the net. They play back perfect on the computer, they even look look on the finished DVD if I play it back on the computer. But crappy on the stand alone. So what do I need to do to fix this? They are SVCD files and I am using DVD workshop to make the DVD.
Thanks!
You may have encoded them with the wrong field order first. Try rencoding them with the oposite field order first. For example, if you encoded them with lower field first, then try upper field first.
You'll have to play them back on the TV to see the difference.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
When you used DVDWorkshop to make the DVD, you can bet that it rencoded your SVCD files.
You'll have to go into the DVD Template settings of DVDWorkshop to change the field order. Don't aske me how, It's been over a year since I've used DVDWorkshop. You may want to check the help files.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Problems with play back packard bell dvd player
By muay in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 12:08 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 02:49 -
DVD created with Panasonic DMR EZ 485v doesn't play back on computer
By gray9965 in forum Authoring (DVD)Replies: 2Last Post: 5th Jan 2010, 14:23 -
DVDs play on computer but not on DVD player
By audax in forum Authoring (DVD)Replies: 21Last Post: 16th May 2009, 06:54 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 11:09
