Please help me. I wish to make a slide show DVD which can play continuously without pressing any button on standalone player. It is for demonstration purpose in shop window. I have Ulead Slide Show, Video Studio 6 and MemoriesOnTV, Thanks in advance.
kfc888
There are lots of ways, but this may be the easiest.
1) Make your slideshow in Mpeg-2 format.
2) download a free 30 day trial of DVD-Lab (you can find it in the tools section)
3) Make your Slideshow Video as Motion Menu in DVD-Lab. Make sure you don't set time-out and your Slideshow will loop indefinatly.
Now when you insert the DVD into your player, it will start the Slideshow and replay when it finnishes.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You have the software that can do what you want.
I have used Ulead Slideshow and MemoriesOnTv and they will both make slideshows that play continuously.
i prefer Ulead Slideshow -
Thanks guys. Since I don't have DVD-Lab, I will use Ulead SlideShow and give a try.
kfc888
Puting a slide show and a video separately onto the same DVD
By coastie in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2011, 05:44 -
Need DVD Slide Show software recommendation FAST!
By lbblock in forum Newbie / General discussionsReplies: 11Last Post: 14th Mar 2010, 15:58 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 09:55 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37
