I've wasted some disks and have searched for the answer but how do I get these files to a playable DVD R/W?
I have used IFOedit and VOBrator to filter out the unwanted misc items on the backup movie and now need to get them to DVD. I have the RecordNow that HP uses and it burns & copies fine but do I have to use another authoring program like my Pinnacle studio to get a playable DVD?
Thank You
If you didn't mess up the DVD structure, just burn
the VIDEO_TS folder to a DVD as data.
if you did mess it up (likely) then you will have to put the pieces
into an authoring program.
or...
Use DVDshrink to select the parts you want.
You end up with a playable DVD that way -
Thank You!
I just burned the video_ts folder and it all worked great. No Xcopy stuff just the movie!
Thanks again
No sound playback on copied files from HDD Camcorder
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th Nov 2012, 07:36 -
manually copied of .MTS video files back to Panasonic HDC-90 memory card
By Rovi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Jan 2012, 12:17 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
missing some DVD files copied to disk
By snafubaby in forum Authoring (DVD)Replies: 0Last Post: 31st Jan 2009, 00:26 -
AVI files are too small when copied to a DVD
By lmcnlcy in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2008, 00:44
