Hi, I'm able to use Tmpgenc DVD to burn my VCD clips that the left audio channel is different from the right audio channel. The DVD can be played in my DVD player and I can choose to hear the "left" or the "right" or both, because TMPGenc DVD creates two audio tracks from my clips. My problem is that Tmpgenc DVD is not very stable. and there are some bugs that bother me alot. Like the Divide by zero problem... there is no way I can tell if there will be a divide by zero in the mpeg clip, I can only tell if I play all my clips in Tmpgenc DVD before the program actaully creates a DVD. But it takes TOO MUCH work and time. I'm just wondering if anyone has a better software that I can use so that I don't need to deal with those bugs??
Results 1 to 1 of 1
Ripping rear audio channels only from DVD
By bradg84 in forum AudioReplies: 7Last Post: 15th Aug 2011, 00:27 -
DVD Flick - 'cannot load audio track 2....has more than 2 channels'
By silver007 in forum Video ConversionReplies: 0Last Post: 14th Aug 2009, 20:55 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 00:15 -
rip dvd folder and keep both audio channels ???
By hulinning in forum DVD RippingReplies: 12Last Post: 16th Feb 2009, 11:43 -
DTS 5 channels audio in TMPGenc Author 3
By cajmere in forum Authoring (DVD)Replies: 7Last Post: 15th Dec 2007, 07:55
