Well,
Since weeks I've read a lot of subject about DRU500AX not burning many DVDR 4x at 4x but 2x.
I have this issue with Datawrite DVDs, otherwise I can burn memorex and verbatiom at 4x without issues.
My conclusion is that I haven't any software or cabling issue, but media or drive calibration problems.
However, I've make an experience to try to understand what is the problem. For that, I've used Nero Info Tool to get info on a memorex and on a datawrite DVD (blank onces).
For memorex, info tool report:
Write 4x
Read 8x
for datawrite I have
Write 4x which is fine
Read 2x... strange no ?
But that's not, once burned, the datawrite report:
Write 4x
Read 4x !!!
If someone can explain this, I will be happy.
Also, when you make a speed test with nero5, the speed at 2,5x.... therefore Nero said the burn speed will be 2x.
Will be great if someone with a Pioneer DVD burner can perform the same test with those Datawrite, just to see if it is the "wrong" read speed which is the issue.
Results 1 to 15 of 15
Go back to 2f - it's rock solid. Any problems with this firmware will be due to the disk not the burner.
Regards,
Rob -
Well, I've run a long time with 2f and get the exact same problem.
Is there any known problem with 2g ? -
Chill........... use some decent media and see what results you get - at least it will give you an idea of where the problem lies.
Datawrite and Sony DRU500AXRegards,
Rob -
I know.... I burn Memorex 4x at 4x, that's my favorite DVDR now.
I've just tested the datawrite v2 to see if there was any improvement... bullshit. -
Memorex & bulppack not suggested for the Sony. Use Accus.
Also:
main page
left column
dvd writers
search for yours & what works.
BTW, how does one go from G to F? -
Originally Posted by handyguyRegards,
Rob -
Originally Posted by movie freak
I can mail it to you if you want.Regards,
Rob -
You can get all of the firmware releases for the Sony DRU-500A at this site:
http://www.sonydru500a.com/
Tivo to DVD Burning Issue
By jdogg2603 in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2010, 06:27 -
burning issue
By jfree in forum Newbie / General discussionsReplies: 6Last Post: 20th Nov 2008, 02:06 -
dvd architect burning issue
By merray in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2008, 01:38 -
Read Error Issue with Burning
By Evhmoon in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2008, 09:39 -
Strange colour issue when burning an MKV
By baldrick45 in forum Authoring (DVD)Replies: 2Last Post: 23rd Sep 2007, 17:52
