I have joined the throng and bought myself a DVD Burner at last - Pioneer 106a - and am now looking at my collection of (x)VCDs.![]()
I have searched through the guides and the main one using TMPGEnc DVD says that burning a (x)VCD file may not work.
Can anyone put me in the right direction of how to burn (x)VCDs onto DVD, without having to re-convert.
Thanks.
Cole
dvdlab can do that
Music was my first love, and it will be my last -
Yes, but it may not play in any particular standalone.Originally Posted by akbor75
For VCD on DVD to be DVD compliant, the audio must be upsampled to 48Khz, the framerate must be 25fps (PAL) or 29.97fps (NTSC). 23.97fps is not supported. The res must be correct for VCD (352*288/240 PAL/NTSC) and the video must not exceed 1850Kbps data rate.
Hope this helps. -
Bugster.Originally Posted by bugster
Thanks, that was the missing piece of the jig saw for me. Thanks very much.
Cole
Burning mixed/split mono VCDs
By ministry88 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 21st Jul 2011, 13:04 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28
