Hi,
I'm having problems in playing movies with power dvd where i recieve the mentioned error(error code 8007001).And the message that some hardware attached to the system is malfunctioning i get the same message on my other pc as well.Anyone have an idea what could possibly be the problem.Can't use decrypter or any dvd related software for that matter it seems for dvd related purposes.In addition easy cd 6.0 says invalid parameter when attempts are made to backup material.Hope this is the right forum mines seems to multi related problem![]()
Results 1 to 1 of 1
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Parameter is incorrect
By xstoanurag in forum ComputerReplies: 2Last Post: 16th Jun 2011, 20:43 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
What parameter in Gspot or MediaInfo shows if AVI will play in DVD player?
By jimdagys in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 01:58 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 05:01
