  1. Member Gritz's Avatar
    Feb 2003
    What is the best way to take an AVI file to the DivX format? Do I need to go through the entire DVD process first and then use a program like Fair Use to convert? Or is a program available that can convert the avi to the Mpeg4 avi?
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
  2. As long as you have the Divx codec installed you can load the avi file into Virtual Dub and have it do the conversion
