I have used my Phillips DVDR75 to put home movies onto DVD. I would like to make copies to send to family members but when I use the Sony DRU 500A in my PC to try to do this I always get errors. I have tried Nero 6, Instant Copy & DVD-Decrypter without success. The same problem applies to DVDs from a friend's Phillips DVDR880 but I have had no trouble copying DVDs from sources other than Phillips. Phillips say it can't be done. Does anyone know different?
Results 1 to 13 of 13
It's tough to EDIT Philips created discs....NOT copy. Use DVDDecrypter in ISO READ mode....the go back and use ISO WRITE mode. This will also keep the original Philips menu screen.
Originally Posted by BrezoPinnacle Studio 8 and DV home video editing (ver.9 already home)
Thanks for the help. I'm now able to copy some of the DVD+RWs and DVD+Rs but in more than half the cases I get an I/O error at 99% of the read process. Any thoughts?
i use to have the same problem with my 880 what you have to do is do a straight copy disk to disk without copying to harddrive used to work for me hope this helps
1. Did you finalize or make disc compatible (don't remember exact name) ???
2. Maybe your discs are not good. Sometimes when quality is bad, end of the disc is not made very well.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
like i said just do straight disk to disk and it should work i had the same prob the burning software i used was recordnow max hope this helps
If you just use copy function,it will made the quality worse.I use clonedvd to copy then dvdshrink.It works great,no much difference between original and copy.
Originally Posted by jimmyinhawaiiPinnacle Studio 8 and DV home video editing (ver.9 already home)
I only use Accu media in my sony with 100% success. For sony use the right media.
Phillips 3576H - copy protection error when recording from TV
By robjv1 in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2009, 15:30 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
DVDs made with ffmepgx
By dlg1989 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2009, 14:05 -
can't copy home made dvdr
By pressthe6 in forum Authoring (DVD)Replies: 20Last Post: 29th Nov 2007, 10:35 -
Copy home-made DVDs to my computer hard-drive
By CdnMark in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2007, 23:50
