Results 1 to 9 of 9
  1. Too many hits (33488). Try again and specify your search better, add more keywords or google search for in our forum here.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    You need to answer more questions!! :P
    I thought you had answered all unanswered posts.
  4. Member SaSi's Avatar
    Jan 2003
    Hellas
    I got 32,993 hits and still the same message.
    Perhaps a modification to the link to perform a filter automatically - such as ignore any unanswered posts of more than 6 months?
    It's a shame the feature is "broken". I used to browse through unanswered posts from time to time.
    The more I learn, the more I come to realize how little it is I know.
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Guess baldrick fixed it. It works now.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    It works but it uses all cpu usage....I must fix some sql indexing.
    Dec 2002
    Move them off into a history table? Put it under advanced search options, to search into the history/archive table? I mean a dead 6 month old post is pretty useless to answer anyway.
    Limit your querry return to the youngest 512 hits? That way narrowing the search results in go further back in time?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    I limited it to latest 6 months.
  9. Thanks, thats great
