I just bought a Pioneer DVD-343, a started playing some SVCD's that I had burned on maxell 700 mb CDRs using Nero 5.0.0.9. The quality is awesome, however, every once in a while the picture breaks up and the sound becomes distorted or a second or two. It doesn't happen all the time, and only usually 2 or 3 times during the entire length of the SVCD. Is it the CDR's that I'm using or the Nero program?
Or is it something I have to live with? The SVCD mpg files play without any problems when I play them on my computer using WinDVD.
I have a Pioneer 333, and I am messing with the bitrate to see if it makes a difference. But it seems like the motion blur problem can be solved somewhat by lowering the bitrate a bit.. this site says the max bitrate is around 25kbps for my dvd player, and I use TMPGEnc, 2 pass variable bitrate. I set my max bitrate at 2300 to account for audio, however I still get block noise...
Can anyone help? I think my problem is the same as yours.
Pioneer DVR-550h Problems
By sliverman in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th May 2011, 03:43 -
PIONEER-610AV-K region problems
By matt2112 in forum DVD & Blu-ray WritersReplies: 8Last Post: 28th Aug 2009, 16:18 -
Pioneer 111D problems
By EGrier in forum DVD & Blu-ray WritersReplies: 12Last Post: 25th Oct 2008, 01:35 -
Pioneer DVR-420H Problems
By belder in forum DVD & Blu-ray RecordersReplies: 5Last Post: 3rd Jan 2008, 13:20 -
Pioneer 112D problems
By Xande in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th May 2007, 22:13
