Hi all.
I have something that's been bugging me about VS7.
The problem is that there are options for exporting a "greeting card" or a web page with an embedded (DV-AVI format?) movie, but there don't seem to be any options to simply save/export your edited work in real or WM or even mpeg 1 format as a simple video file.
The manual talks about how to capture straight to WMV or other web-appropriate formats. But that doesn't tell me how to edit and then save in those formats.
So how do I get edited video out of VS7 in Real, QT or WMV format? In case I need MF2, I have that as well, with the "advanced" mode registry hack.
--Shayne
Shayne,
In ULEAD VideoStudio 7...
1. Click SHARE > CREATE VIDEO FILE > CUSTOM;
2. Next you should observe a CREATE VIDEO FILE pop-up menu appear;
3. Observe the SAVE AS TYPE drop-down list;
4. Click the drop-down list arrow to expand the list;
5. Among the various options, you should see REAL, QUICKTIME, and WINDOWS MEDIA VIDEO options.
This is all possible using my FULL version of Ulead VideoStudio 7.
If you don't have the above options, then perhaps you are experiencing a limitation of the "SE" version in which case I would suggest that you consider the UPGRADE:
http://www.ulead.com/store/vs/runme.htm
Hope this helps,
Jerry Jones
http://www.jonesgroup.net
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
export from iStopMotion to edit in iMovie 09
By kvdv in forum MacReplies: 19Last Post: 29th Sep 2009, 08:56 -
Magix movie edit 12 - Divx export fails
By pete76 in forum EditingReplies: 1Last Post: 4th Jun 2009, 04:32 -
WMA-2.WMA-3 files conversion
By sumeshkri in forum Video ConversionReplies: 3Last Post: 27th Sep 2008, 19:52
