Hi
I've just purchased a Pioneer DVR106. When I try and play a DVD or start DVD Player it quits with an error saying that it can't find a valid DVD drive. Is there a fix for this?
Thanks.
Results 1 to 11 of 11
In DVD plater click Open VIDEO_TS folder and choose the folder on your DVD. If that doesn't work, use VLC to view it.
Unfortunately DVD Player bombs out before I even get a chance to access the menu options. Fails immediately because it can't find a DVD player. I need to get DVD Player working if possible so that I can use DVD backup. Presumably VLC doesn't read the keys in the same way.
Cheers. -
According to the site, if you follow those steps it should work.
Sorry Typo hadn't realised that your last post was a link. Duh. Looks like the solution cheers.
Or you could just install it internally and save the firewire case for another harddrive or place your internal cdrw or dvd in it. Thats what I did and you don't need to patch anything it will show up and be fully supported. And my 106D was not a Mac version just a Pioneer that can be read by PC but it works with Macs also. They all do.
snafu099 I think he has a Mac! Great advice for a PC but I think he has a Mac.
Can't install internally because I don't have a bay on my old G3/600 eMac. Edited the program as outlined in Typo's link and all works fine. Backed-up my first DVD last night.
Thanks for all your help people.
External Hard Drive to DVD Player through TV
By illpeeonu in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Feb 2009, 13:02 -
problem burning with external dvd drive
By billybob59 in forum DVD & Blu-ray WritersReplies: 15Last Post: 8th Mar 2008, 20:32 -
Videos stutter from internal drive, but okay off external drive
By ruggrock in forum Software PlayingReplies: 7Last Post: 22nd Jan 2008, 14:17 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47 -
external DVD drive
By uglijimus in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2007, 07:47
