Page 2 of 2
FirstFirst 1 2
Results 31 to 47 of 47
  1. Member Conquest10's Avatar
    Chicago, IL
    Here's what I'm getting:
    IE6:
    HTTP_ACCEPT_ENCODING:
    HTTP_USER_AGENT: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.0.3705)
    Firebird:
    HTTP_ACCEPT_ENCODING: gzip,deflate
    HTTP_USER_AGENT: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.5) Gecko/20031007 Firebird/0.7
    His name was MackemX
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Avant Browser with IE6 (should always be the same as IE)
    HTTP_ACCEPT_ENCODING: gzip, deflate
    HTTP_USER_AGENT: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.1.4322)
    No issues here. Of course this is on my pc...
  3. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    HTTP_USER_AGENT: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  4. So your browser does not support gzip either then Will. Give Mozilla Firebird a try, loads forum pages much, much quicker.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    http://support.microsoft.com/default.aspx?scid=kb;en-us;Q312496
    It may work if you install the latest explorer service pack.
  6. Wait a mo.
    I get this (with firewall activated) "eTRUST firewall by C.A."
    but when deactivated I get
    so perhaps it is not just the browser, rather any TSR filtering HTTP
    traffic or even IE security settings.
  7. I will try the service pack and turning off my firewall (zonealarm) when I get home.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Originally Posted by offline
    Wait a mo.
    Yep, some firewalls filtering https and removes the accept encoding. Check if you can disable it.
  9. Craig, if the IE patch does not help perhaps try activating XP's
    built in firewall and just disabling ZoneAlarm when visiting dvdrhelp -
    that should afford enough protection while you are browsing.
    I find I have to do this often - esp. with URL's with anti-leaching
    software like doom9. With the latest security hotfixes, XP's built
    in firewall is pretty good on it's own - the only big threat being
    those bloody Russian web traps - and there is no noticable slowdown.
    Check out GRC's excellent ShieldsUP test to see if you are
    open to attack. http://www.grc.com
  10. Lost Will Hay's Avatar
    Oct 2002
    I have no idea what the hell is going on, I just thought by posting my results I was helping in some way
    Will
  11. Bloody NTL has gone tits up, so I have lost my cable TV and my broadband. Will have to wait for it to come back on before I can try out the suggestions.
  12. Its Zonealarm that is blocking internet explorer from using gzip. It does not stop mozilla firebird using it though. Have to try and find the setting in zonealarm now and turn it off.
  13. Originally Posted by offline
    Thanks for the link offline, seems I am pretty secure
    Unable to connect with NetBIOS to your computer.
    All attempts to get any information from your computer have FAILED. (This is very uncommon for a Windows networking-based PC.) Relative to vulnerabilities from Windows networking, this computer appears to be VERY SECURE since it is NOT exposing ANY of its internal NetBIOS networking protocol over the Internet.
    Can't see how to disable zonealarm from blocking IE from using Gzip, so I guess I will just use mozilla firebird for DVDRhelp from now on.
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    Use Kerio Personal Firewall 2.1.5
  15. To be honest Mozilla Firebird is quicker than IE even with the firewall turned off, so I think I will stick to using Mozilla anyway, and I seem to be locked down pretty well with Zonealarm.
  16. Master of my domain thoughton's Avatar
    England
    Woo woo!
    Safari 1.2 is available now, and hey presto:
    HTTP_ACCEPT_ENCODING: gzip, deflate;q=1.0, identity;q=0.5, *;q=0
    HTTP_USER_AGENT: Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en) AppleWebKit/124 (KHTML, like Gecko) Safari/125
    GB
    This is with the built-in firewall enabled.
    Cheers,
  17. Wow, just installed mozilla firefox 0.8, this thing flies
