Is there a program to convert XVID to MPEG. I have tried TMPGE but it does not do the sound. If i cannot do XVID to MPEG. Is there a way to convet to AVI or VOB. Thanks in advance. Sam
It's the audio in the AVI that's encoded in a way TMPGEnc can't understand. This has nothing to do with the fact that the video is XviD encoded. You have to extract the audio and convert it to some format that TMPGEnc understands (WAV works best). This is most easily done with VirtualDub. First, make sure your system is equipped with the codec needed to decode the audio - use GSpot to find out this.
The problem is that you can't read the audio of the AVI. Regardless of what you want to encode to, this fact remains the same. Since it's already AVI, it makes no sense to convert to AVI, and if you can convert it at all, you can convert it to mpeg 1 or 2 (and then to VOB) without any differences in the procedure besides using different settings/templates in TMPGEnc.i cannot do XVID to MPEG. Is there a way to convet to AVI or VOB
/Mats -
You are going to need to extract the audio first. This is the process that worked for me.
1. Load file into VirtualDub (latest version). Save the audio as a wave file with no compression (it will be large). Make sure that you set
2. Save the avi with no audio.
3. Load the files into TMPGEnc and process.
There is a more detailed guide in the guide section.
Hope this helps.
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 12th Dec 2009, 23:44 -
XviD MPEG-4 to DVD with Subtitles
By MI6 in forum Video ConversionReplies: 1Last Post: 3rd Jan 2009, 05:09 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 15:50 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
xvid to mpeg 2
By DSLGuy in forum Video ConversionReplies: 2Last Post: 13th Oct 2007, 11:27
