well i was wonderin about tmpge encoder i used it to make a divx file an mpg 1 and it worked but my takes r it continues encoding even after the clip ends it keeps doin something i had to press sop encoding and forcefully end its task the file is ok but does this increase the file size? what does it do all that time? lol
second is that the file i was encodin already had a subtitle and vobsub loaded it and it's permanently existing in the output mpg file ,which brings the question of how could i make subs for my dvd like original dvd movies where i get to chose wether to show the sub or not? does it depend on the authorizing software ,tell me what's the best author in ur opinion and why
also howa different can the output dvd look on my pc than on my tv ratio wise as in 1:1 or 4:3 or 16:9
how could i know my divx original file's aspect ratio and is it best to keep it as the original source?
i used G-spot and it shows no info about that
thnx a million![]()
Results 1 to 1 of 1
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Truely Newbie
By Gayle Richmond in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2007, 15:46
