A while back, I found that I couldn't encode my iuVCR captured files directly. One post that I can't find anymore mentioned that iuVCR couldn't by definition save a file with a constant frame rate (29.97 in my case) and that caused problems.
My workaround was to pull the file into Vegas, and re-save it as an AVI file which I could then encode. An extra step, but it took care of the problem.
A brief email exchange with Ivan (not sure if he has anyone else respond to the emails) cleared this up...unchecking "Master Stream" on the options tab tells iuVCR not to alter the frame rate.
I'm not sure what the master stream is or why the frame rate would change (or be allowed to change), but sure enough, when I unchecked this and encoded a short test capture, it worked fine.
I'm not sure if others already knew this so I thought I'd pass it along just in case...!![]()
Results 1 to 1 of 1
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Rendering multiple framerates?
By Sephisto in forum Video ConversionReplies: 1Last Post: 8th Apr 2012, 13:46 -
Videos with different framerates need to be joined together
By vertigoelectric in forum Video ConversionReplies: 15Last Post: 18th Mar 2012, 04:21 -
Synchronize audio and video with different framerates
By dexter30 in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 15:53 -
Audio from movies with non-standard framerates.
By Maikeru-sama in forum Authoring (DVD)Replies: 16Last Post: 30th May 2008, 18:21 -
Framerates and converting to DVD
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 18th Jun 2007, 01:31
