  1. I am using MainConcept 1.4. What I should select for 'deinterlancing'; none, use top field or use bottom field? My input file is tv-captured avi (divx?) or mpg file.
    Thank you.
    canada
    you dont need to deinterlance if you are going to watch the finished product on tv,deinterlacing reduces picture quality and your tv will display the picture with out the comb effect you see on the pc monitor.
  3. I don't understand why everyone claims that. It's BS. I always make sure my movies are deinterlaced because the lines show up on my tv the same way as the pc. I apply the filter and no quality loss, just erases the lines.
  4. Originally Posted by cooljoe666
    Are you encoding as interlaced ? Should display fine on a tv if its done right.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  5. Member JimJohnD's Avatar
    May 2001
    Ohio U.S.A.
    If you have TMPGEnc you can:
    1. Load your interlaced video.
    2. Click the "Settings" button.
    3. Goto the "Advanced" tab.
    4. Double-Click on the "DeInterlace" option.
    Now for the really cool part...
    5. Select the method drop-down and you can use the arrows on your keyboard to scroll through all of the selections.
    This gives you a great example of what DeInterlacing does to your video. I was really supprised at how much of a difference the method makes.
    http://www.tmpgenc.net/e_main.html
    Mar 2003
    Uranus
    First you don't understand it , and then you claim it's BS which
    would require that you understand it.
    It came in interlaced. It looks OK on the TV . Why would
    just capturing it as is not be the best way ?
    And why wouldn't the recording look exactly the same on your TV.
    You are doing something wrong.
    If you always make sure it's de-interlaced then you need to post your methods
    because it's a BIG problem that experts have been working on for years.
    Nov 2003
    Charlottesville, VA
    You really need to figure out what's going wrong. You lose a lot of "sharpness" by deinterlacing.
    You are wrong. Read some guides. Start with the ones on lordsmurf.com
