does any1 no how 2 convert ntsc movie file 2 pal. basically wot i want 2 do is to create a vcd. i've got da avi file and need to convert it 2 mpeg(pal) wit TMPenc but i don't no da settings. can sumbody help PLZ???
also would da film lose sum quality from doin dis ?
thanx!
you need to use the VideoCD(Pal).mcf file. That will give you all the right settings to write to a NTSC Mpeg.
Haganb, im a bit confused.do i select videocd(pal) if i want to create a pal mpeg or videocd(ntsc). sorry if dis question dumb, i m a newbie
Converting bluray movie files to low size files
By AndreL in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 01:06 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 15:43 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 10:08 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 00:18
