  1. Is there another program besides iuVCR that I can use for capturing AVI? My iuVCR will work for a while, then out of the blue, I get an error about "unable to render capture graph settings" when trying to record. The only way I can fix it is to Restore my computer to an earlier date...then it works fine for a while...then the error comes back. Is there any other program I can try? Or how do I fix iuVCR? Thanks
    Apr 2002
    The State of Frustration
    Hello.
  3. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Recently I've been using TheFlyDS which works very much the same way that iuVCR works.
    I actually prefer TheFlyDS because it has a very simple and easy to read AUDIO LEVEL METER which makes it really easy to set your AUDIO VOLUME for the recording/capture.
    Good Luck!
    - John "FulciLives" Coleman
  4. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
