I am trying the DVD-Lab demo. I have my video stream and my audio stream. Finally, I have my audio stream as an .mp2 and have delayed it to keep from what I call the "Kung-Fu Movie Effect" (i.e. audio video sync). What I am baffled about with the program is where I can view the finished produce without having to burn it to a DVD.
I need to see if the delay I set up is correct and make adjustments, if necessary.
Thank you!![]()
Aaahh Lad I like to view my finished produce after a (hex) dump.
wmp will play it or any dvdplayer program, select file as input and you can check everything looks ok... you'd be silly not too.
Um, I swear I am looking for it, but I cannot find hex dump anywhere in dvdlab. How do I do what you are talking about? Thanks again.
Wait, I think I found it under compile though it's not called hex dump. Sorry. Thank you. -
typically wherever you compile the authored dvd to, u can playback that folder using powerdvd/windvd.
Just got finished watching "The IT Crowd"
By freebird73717 in forum Off topicReplies: 1Last Post: 30th Jul 2011, 23:41 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
Simple VOBs to DVD-ready MPEG 2 HOW?
By Flarch in forum MacReplies: 8Last Post: 6th Jan 2009, 09:34 -
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
dvd lab question
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 23:44
