OK I totally screwed up when updating the firmware on my Sanyo dvd-7201.
The machine went TOTALLY dead. No leds, nothing. It's like it is not pluged in.
So am I totaly screwed? Say it isn't so.....what can I do?
Help!!!!
Jimmy![]()
Flash it again ???
I think the problem is the player will be completely dead.
Seems as if it must have lost power during the flash upgrade, jocoman, which basically passes a death sentence on your player. Sadly, you will have a trashed EEPROM. Assuming you have a socketted EEPROM rather than a soldered one, you will need to get it re-programmed externally using a proper EPROM programmer - as you have a disc with the firmware file, that should be sufficient.
See here for a list of folks who'll do it for youWebmaster of Area 450, the independent site for owners of Sampo and Maxent DVD products the world over -
Does it work? can u try again? what happened after you restarted the computer. Is ur computer dead or what??????
Yep, you are totally screwed!. Sorry I didn't read ur post, I though I was in the DVD burners section.
I think i may have just screwed up my pc next door....
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Aug 2009, 00:13 -
Editing and updating
By Jomapil in forum FeedbackReplies: 2Last Post: 15th Feb 2009, 05:35 -
updating windows xp
By aruwin in forum ComputerReplies: 12Last Post: 15th Oct 2008, 14:00 -
Screwed Up the Muxing
By Mnem in forum SubtitleReplies: 6Last Post: 16th Apr 2008, 15:40 -
updating DivX from 4 to anything else ...
By HJSis1 in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2007, 18:30
