I want to use my laptop (XP) to run encore and then send the task of burning to my desktop (98se)
Is this possible?
Yep, its possible. When you have created your DVD structure in Encore. Go to BUILD DVD and select BUILD TO FOLDER. When it has built the folder, you can can test the playability out on your laptop DVD Player, then copy the folder you have created on your laptop to your desk top PC and burn it.
TOMMO
Question about 720p HDTV networks
By jd594 in forum DVB / IPTVReplies: 3Last Post: 8th Sep 2010, 07:50 -
Books on Video Server Networks
By m4Rio in forum Off topicReplies: 0Last Post: 12th Aug 2010, 09:42 -
Looking for a list of that will state which HD format TV networks use
By the_importer in forum DVB / IPTVReplies: 10Last Post: 21st Aug 2007, 14:42 -
Question About Networks Switching to HD
By kerrex_2006 in forum DVB / IPTVReplies: 4Last Post: 20th Jul 2007, 17:13 -
How do I capture videos from CBS, other networks
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2007, 23:19
