I have a ripped DVD and the subtitles in sub or srt format.
I have already converted the avi xvid file into mv2 and the audio file into wav and made my scenarist layout.
I just can't import the subtitles into scenarist. It only accepts stt file.
I downloaded S3Cnvtr.exe (which claims to convert to scenarist format) but I can't do it...
anyone: any suggestion?
thanks
MaestroSBT converts text-based subtitles (ssa actually) to graphical format subtitles like sst (check that you get an sst text file with a series of bmp files after conversion). I suspect this is the format scenarist requires.
To convert your srt subs to ssa first, there is srt to ssa tool or SubRip.
The other part which, you say, is in sub format ... What kind of sub actually? Is it text? -
well just found out what to do to a .sub text format:
open with sub creator [can play along with the avi file!!!]
make corrections if needed
export as ssa
open with maestro directly
save as scenarist with bmps
Video Import Help with VirtualDubMod - Subtitles Workshop!
By rp0094 in forum Video ConversionReplies: 13Last Post: 10th Dec 2009, 19:32 -
Exctract Subtitles from .vob -> Import into Sony Vegas or DVD-Architect
By mltwitz in forum SubtitleReplies: 4Last Post: 4th Oct 2009, 03:16 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 07:16 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 06:38 -
Import subtitles from a commercial DVD into Adobe Premiere Elements?
By haggis999 in forum Newbie / General discussionsReplies: 44Last Post: 11th Apr 2008, 20:44
