i been trying to read a lot of post in this forum but i just could get the exact answer.
What is the best resolution should i use to capture video in .avi format for editing and final output to VCD?
i been trying 320x240 but it seems the quality is a little bit low... i tried 740x480 but now i got capturing problems... lots of drop-frames during capture.
is there a resolution between 320x240 and 740x480 that i could consider to use?
thanks!
Good day.
You didn't mention what capture card and software you are using to capture in AVI format.
720x480, 640x480, 352x240, could be your options. ( VCD resolution is 352x240 so capturing at 320x240 will definitely produce lower quality video.) -
thanks!
i'm using PixelView Play TV Pro using drivers from sourceforge.com
i have also install HUFFYUV codec
i tried AMCAP & VirtualDub as my capturing software!
i have a 80G Baracuda (Seagate) HD as my capture drive.
My hardware is a 1.8G P4 with 320MB RAM on WinXP Pro
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 16:40 -
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 23:29 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 02:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 12:57 -
capture resolution
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2007, 15:45
