What's the best top of the line burner out now?
I finally got job.
And want one.
Also,needs to be dual or triple format (if there is triple format)(which there probably isn't)
Results 1 to 16 of 16
This is a block of text that can be added to posts you make. There is a 255 character limit
look into what lg have(GSA-4040B) ,i believe they got what you want
I just watched a special on Tech Tv and they reviewed about 5 of them check it out.
http://www.techtv.com/holiday/story/0,23008,3509477,00.html
I believe though if you want all the formats including dvd-ram you should look at the LG GSA-4040B. It was also rated the best on Tech Tv. Also check out cnet.com, they have their 10 favourite drives too. -
I shall look at them. 8)
This is a block of text that can be added to posts you make. There is a 255 character limit -
Well,I'm actually thinking of getting an 8x dual burner instead.
On the otherhand,why should I use DVD-RAM for?
What's DVD-RAM good for?This is a block of text that can be added to posts you make. There is a 255 character limit -
Make sure you stock up on DVD+r's, for that's all you can write at 8X. 8)
You said best: The best is the Plextor 708A I would hold off and buy second best (Pioneer A06) for around $130 oem and wait for the dual layered burners next year.
here's a review of the 4040B I would avoid
http://club.cdfreaks.com/showthread.php?s=1ef6b0667b5660f3f32e66f96a7e9bf6&threadid=78...5&pagenumber=1
I love this review of the Plextor 708A by a person on epinions:
http://www.epinions.com/content_118606958212 -
What so good about DVD-RAM?
How are they like a hard drive?
on ram you can just drag and drop things and delte things like a hard drive. For example you can drag 5 word documents, if you want to delete one of those documents, you just delete it and the other 4 are still there w/o reformatting your disk. Then you can still add more stuff to the disc (over 4gb). No need to finalize or close the disc. It's like haveing a 4gb hard drive. Very nice feature for backing up data
Are there any triple format 8x burners out?
I am using a Pioneer 106(OEM) which i got for £99. I have had it for just over 2 weeks, and no coasters yet!
bnbhoha?
here's a review of the 4040B I would avoid ?????? ( yes I would avoid that review also! )
I suggest unless you have used one of these DVD burners, you refrain from
poo poo-ing it, if you go to tomshardware.com, they rate it highly, as I do.
Colindale:
You're right, I don't own the 4040b burner, but I did do extensive research on many drives. Many people like yourself like the drive. I'm just passing information. This reviewer did a through test whereas Tom's Hardare and most other place did not. You're dvd-rs may work fine, but if there are really errors on the disc that may affect performance now or in the future, do you really want to take the gamble? I guess I should have just said read the review & decide for yourself, which I did and bought the Pioneer A06 -
bnbhoha?
???You're right, I don't own the 4040b burner??? ( enough said!.) -
Gosh Dangit! You're so cool, you just gotta get the last word in, huh? Like I said, read the review and then decide for yourself
Buying a New BR Burner
By golfnut in forum DVD & Blu-ray PlayersReplies: 22Last Post: 11th Apr 2012, 10:36 -
How do you know when you have a bad burner?
By will7370 in forum Newbie / General discussionsReplies: 5Last Post: 18th Feb 2012, 12:14 -
Is it time to get a BR burner?
By beavereater in forum ComputerReplies: 10Last Post: 8th Nov 2011, 00:37 -
What burner would work for me?
By nouseforaname in forum DVD & Blu-ray WritersReplies: 19Last Post: 13th Apr 2010, 00:02 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
Plextor ... king of kings in recording technology... or mitsumi Dxxxx
