Hi!
I would like to know what dvd burner:
-LG 4040b
-Pioneer 106d
-Lite-on 411s
and dvd (-+, 2x and 4x) used, are compatible with the dvd
player Sony DVPNS-300.
Thanks!
bye bye...
I have an NEC 3500AG v2.18 drive and I have never had any problems
playing any burn't discs of any type using TMPEG DVD writer v1.0.2 powered by Sonic Solutions. Nero ROM reloaded also works well on burns.
Don't use ElbyCloneDVD2 for burning lots of issues there with the ElbyCDIO low level driver, they may have fixed it but once bitten twice (don't use it ) shy.... lots of bad burns when you want to backup the disc again. Although its clone function is very easy to use and one of the best I have found for transcoding DVD-9 to DVD-5.
Always select the burn speed that is correct for the blank disc never burn higher if the max is x8 then burn at that speed or lower.
If you want to use Video discs, use VCDEasy and CD-RW media for 100% sucess, only a select few CD-R will work Nashua Mutlidrive compatibilty are the only CD-R I have found to work on this player.
Spideray
Sony DVP-FX970 compatibility
By tigranmj in forum Latest Video NewsReplies: 7Last Post: 6th Apr 2012, 11:19 -
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
can't copy 300
By Bamahusker in forum DVD RippingReplies: 5Last Post: 21st Feb 2008, 15:55 -
Sony RDR-HX720 compatibility with Home Theater
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jan 2008, 23:44 -
Sony RDR-HX 720 compatibility with Onkyo HT-S990 7.1 Channel THX
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jan 2008, 04:55
