OK I'm trying to convert an PAL Dvd to NTSC Dvd, I've succesfully converted the Video but having trouble Processing the audio, after doing some tests I've narrowed the problem down to BeSweet.
I converted the AC3 file using the preset "PAL to NTSC 25000 - 23.976" after transcoding I then import my video and newly created AC3 into my authoring program (also tried various other authoring programs so aint that) once the authoring is finished, I then burn to disk, but when trying to play in a standalone player I get no audio.(tried different players too).
ALSO Which I Find interesting is:-
I've noticed that if I play the Vobs off the Hard Drive which where created by the authoring program, the audio is present (using media player)
Now when I drag that same vob over to PowerDVD the vob plays without the audio, wierd eh :/
Now I cant figure what I'm doing wrong here, I have the AC3Enc played correctly too.
Is there any other audio program I can use to stretch the audio? or can someone shine some light on the above?
many thanks
You could convert the audio to MP2 to eliminate
possible AC3 problems with players and authoring programs. -
Thanks man! Converted to Mp2 and authored and it work perfectly, I've been pulling my hair out for the last 2 says wondering what I was doing wrong, cheer
problem with besweet while changing 25 to 23976 fps
By montevo in forum AudioReplies: 5Last Post: 23rd Jan 2012, 04:39 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 15:44
