Hi,
I want to maintain PQ during video convertion and here is what i am using:
I am using AVS VideoConverter 2.5 to covert VOB to MEPG 2 and using AVI codec to find out VOB's bitrate, frame size, frame rate etc.
From AVS VideoConverter, i can edit bitrate, frame size, frame rate etc to match exactly as my original VOB files format. But i was wondering if i do that way is it going to maintain same picture PQ after i covert to MEPG 2 format? What about if i change to higher bit rate or frame size? Is it going to covert better MEPG 2 than original VOB format in terms of PQ?
Which methods will give me better or maintain same PQ after convertion to MPEG 2?
Results 1 to 1 of 1
Best format to use to maintain video quality?
By Blackhawk1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Apr 2013, 02:17 -
How to maintain quality with avidemux? (which video codec?)
By tlee in forum Video ConversionReplies: 7Last Post: 7th Nov 2010, 08:39 -
batch WMV to AVI that will maintain video bitrate and frame dimensions
By chief1972 in forum Video ConversionReplies: 2Last Post: 27th Dec 2008, 14:17 -
maintain quality output file after cutting video
By karebo in forum EditingReplies: 14Last Post: 24th Feb 2008, 06:47 -
Video convertion
By kireetkvn in forum Newbie / General discussionsReplies: 3Last Post: 10th Sep 2007, 01:50
