is it possabile to make audio music dvds - The same as a standard 80min/700meg music cd. If so, how?
How many min of music can you fit on a DVD?
Results 1 to 9 of 9
Yes, but it wont play on regular CD-audio players.
I have made MP3 - DVD albums (holds about 5000 songs), but I can only play them on computer. -
what I wish to do is put 3 or 4 music cds onto one dvd disk and play them on my dvd player, which is not mp3, so it needs to be burnt as a music disk, if possabile.
sorry aerodeck dont think that is possible but like the last post you can make a data disc that holds (5000) tracks and play in a computer
you could -Originally Posted by aerodeck
- rip all the songs to .wav files
- convert all of them to 48khz (dvd standard)
- make a dvd that has a menu for each album, with submenus for each song
- make the background music for the submenu the song itself.
I'm sure there's an audio software with batch-conversion abilities that would do the upsampling on the wav files.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Hi,
Have a look to the 3 VideoCD Audio guides at:
http://www.digital-digest.com/dvd/articles/index.html#vcd
They are focused to make audio compilations, playable in non MP3 compatible DVD's. It could be an easy and cheap solution for you. Good luck!
Paco -
My DVD player can even play .wav from ISO DVDs.It's not in the specs, I just tried it out and it worked.I'd give it a try.
Housepig has a good idea. I think you could get up to six hours of sound using low video quality
Instead of a submenu, make a slideshow with 1 slide the length of the song. Less space than low quality video. Better picture.
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
