First up, TPGO's helpful guide made Sizzle so much easier to understand, but I and a lot of other people have had issues making it work, but I came up with a workaround that works perfectly for me!
The issue is that it supposedly can handle MPEG1 and MPEG2 files AS IS.
It CAN, but only if they are already up to DVD standards as far as AUDIO is concerned. I built a disc with some music videos, worked perfectly, tried one of some TV episodes, some worked, some didn't. Decided to go back to the drawing board, and instead of just selecting the complete MPEG file as a new title, I selected it, but under video and audio, I selected the elementary streams I'd gotten from running the file through ffmpegX. This was how the older version Sizzle worked, just using the basic streams, and if you do the same in the new version, you get great files, but you also get the bells and whistles of menus, etc.
Works like a charm!
Thanks, Henry for Sizzle, and thanks again TPGO for the tutorial!!! I have a boatload of work to do now.....gotta make some custom DVD's for stocking stuffers!!!
Results 1 to 9 of 9
Originally Posted by Dunnymanand thanks again TPGO for the tutorial!!!
One day I will meet him! -
tgpo,
are you sure?
I mean I thought TGPO was real button downed,
clean shaven, corporate american type of guy.
That seems like, if nothing else, the alternate
"Spock" version of you.... :P
and say, have you finished your DVDSP2 tutorial yet....?
To be perfectly honest. I havn't even started.Originally Posted by terryj
I've been working on the script for my summer movie and finals at school. But I'll make it a point to try and get to it.
Farging iceholes.....try to compliment a guy, and get ragged for spelling his name wrong.....jeez....
okay TGPO or WHATEVER your #$%^&*@ name is, I thank YOU for the fine tutorial.... :P -
Straight from Johnney DangerouslyOriginally Posted by Dunnyman
Sizzle help
By danielmak in forum MacReplies: 3Last Post: 3rd Mar 2010, 08:37 -
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 07:57 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 14:45
