I'm adding the SSA subtitle file to the movie with VirtualDub Filter
and then I starting a Frameserver in VirtualDub that work fine
but the I want to export the Frameserver file in Tmpgenc but I always got a error messeg
the messeg is : Unsupported File
why pleas help me with this
Sorry about the bad english
I used to have that problem a lot especially when adding subtitles. Just changing the priority ratings never helped the issue (as most of the guides will tell you to do). The only thing I've found that works is to save the file as .avi instead of .vdr and give both the frameserver name and file a very short name (example x.avi). TMPGEnc gets confused by long filenames...especially if there are special characters. This works every time for me.
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
Problems with ffmpeg adding subtitles to MP4
By videobill in forum SubtitleReplies: 3Last Post: 2nd Dec 2010, 19:49 -
(Newbie) Adding subtitles with TMPGEnc 3
By mrwednesday in forum SubtitleReplies: 0Last Post: 2nd Mar 2010, 20:00 -
problems with adding the sub file on VirtualDub
By yuunhaa in forum SubtitleReplies: 7Last Post: 25th Feb 2010, 12:39 -
problems adding 5.1 sound using virtualdub mod??
By pete7769 in forum AudioReplies: 4Last Post: 24th Jul 2009, 16:45
