  1. Hi
    Is there any way to get good backups of filmed dvds (tv shows) with DVDShrink or Instantcopy. I tried to Back up OZ season1 with both with bad results. I mean, is pòssible to change some settings to get the best quality?
    thx a lot
    cheers, sammo
  2. Hi sammo.
    What version of DVD Shrink did you use, and what level of compression was applied?
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  3. DVD Shrink (and the other transcoders) work by removing part of the MPEG video data, this results in lower quaility. If you shrink the DVD a little the quaility lost might be below the ability to detect, shrink a lot and it's very noticable.
    To shrink a large DVD9 disc (Oz ~8GB+) to a single DVDR (4.3GB) is going to result in a quaility hit. For best results try running DVD Shrink's 'deep analysis' first.
    But for best results you really need to re-encode (TMPGenc, CCE, etc) the video instead of transcoding, then re-author the DVD. A more involved and much longer process, but it results in the best quaility.
    Dec 2002
    It's incredibly simple.
    Re-Author mode and drag 2 eps (1 hour eps) per DVDR and go.
    You can go 3 (1 hour) eps per DVDR, but you will want Deep Analysis for this. It's a trade-off of $1.20 DVDR versus an additional hour in the backup process versus quality.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  5. Originally Posted by Gazorgan
    You forgot the most important line. Re-authoring with DVD Shrink doesn't let you keep menus. Simple but menuless.
  6. thx a lot for the help by the way
    I'm using Dvdshrink 3 beta 5, the latest I think
    When I say really bad results, I mean that I get tremors in the video why playing on my tv screen. some time ago when I convert DVD to svcd (before having DVD Burner) I solved this with a deinterlace filter, I can do that again encoding to DVD with Tmpgencoder, but I loose the menus, that's why I tried DVDShrink and Instantcopy. The result with Instantcopy was not bad at all, a few tremors every 2 minutes or so, but with DVDSrink it was a total crap, tremors all the time. DVDsrhink works really good with all the other stuff I encode in PAL. I guess the option I have is to encode the episodes my self and then author the DVD with DVD maestro or whatever...
    thx a lot for your help dudes
  7. One more thing, sorry
    I'm in europe, so I play the dvds in a pal tv screen. I bought before NTSC dvd's (24 season1 and 2) and play nice in my dvd, I think that the backuped ntsc should play right too isn't?
    don't think that has something to be with my problem, but I'll let you know
    thx
