  1. When I make a disk with TmPgEnc author, the disk play well on my dvd player but when my dvd player load the disk it plays the first title instead of the menu. I need to push the ''Menu'' button to acces to the menu. Is there a way to make the Menu to appear first instead of the first track without pushing the ''Menu'' button.
    With DVD Maestro you can choose what is going to play first when a dvd player load the disk, but I don't find anything about that in TmPgEnc Author.
  2. You may be able to find it other ways as well but the setting you are looking for can be found by:
    Going into Edit menu theme and there will be a button at the top "Settings of the menu display"
    I hope this helps
    Change the Firstplay action: to Display main menu. You find the Firstplay action: under the "Create Menu"-step.
