Just for your info, I read most of the guides, which I found to be very informative and interesting.
My question is about backing up some of my dvd movies. I want to make copies of some the movies that I like to watch alot, like the matrix, starwars, etc...
Problem is they are all dual layered. So there needs to be some sort of compression to fit it all onto one dvdr. (i have a dual formate buring by the way +- r)
So I read the information about the differnt programs that could be used to fit a dvd9 onto a dvd5.
Here is my question. I have a 56inch widescreen hdtv. The video quality is my top priority. My dad and I are both video fanatics. When I make these back up copies, I want the best quality I can get. I dont care about anything else. The menues, extras, other languages. I just want the movie with the english dolby digital track. (HIGHEST VIDEO POSSIBLE!)
Which program will best suit my needs?
Results 1 to 17 of 17
The video quality is my top priority. My dad and I are both video fanatics. When I make these back up copies, I want the best quality I can get. I dont care about anything else. ..(HIGHEST VIDEO POSSIBLE!)
If you want the movie all on one disk and the files are too big for one disk then you'll have to compress it- but then video quality wouldn't be your top priority- getting it on one disk would be the most important. -
so does dvd shrink allow me to completly get rid of extras and the other language tracks?
Yes if use re-author mode you can select just the movie.
how do you split a dvd using dvd shrink?
DO you just make 2 re encodes...one with the first half of the movie
the other with the 2nd half using the start end tool? -
Originally Posted by abs9986
ok my last couple of questions.
Does dvd shirnk move the encription on the dvd, or do I have to use dvd decrypt. If I use decrypt, then do I remove the encription before or after using dvd shrink.
Second question: What program do you recomend to actually burn the dvd? -
"Does dvd shirnk move the encription on the dvd...?"
Yes, it does remove it. -
Ok so dvd shrink will take care of the encription for me.
Now what bout me second question. What burning program works for you guys with dvd shrink. I would prefere it to be free, but if I have to spend like 20 bucks on it, then fine. -
Alot of members here use either RecordNow Max or Nero.
SLICK RICKOriginally Posted by lordsmurf -
If burning to DVD-R, I'd suggest you give burnatonce a try.
http://www.dvdshrink.info/burnatonce.php
It's a free, user-friendly and reliable burning software.
It can be used to burn to DVD+R but require a third party file and registration key (not easy to get from what I've heard).
They also do not give support at its official forums when burning to DVD+R. -
ifoedit can also easily strip the movie and ac3 files down for you. Also you can pick up dual sided ritek discs if or when you want to slip the dvd into 2 and keep everything contained on one disc
ifoedit guide
http://www.doom9.org/index.html?/mpg/ifoedit-2dvdrs.htm -
if you are going to go with dvd shrinkm download dvdshrinkiso. This automates the process of burning (using decrypter), making it a one stop shop (if you have a dvd and a dvd burner).................and its free!!!
otherwise, I use nero express (latest non 6 version)
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
